Hey guys,
Just finished some procedural modeling. I'm trying to create a digital asset out of my network. I've collapsed the entire network into a subnet. When I right click on it and choose “create digital asset” I keep getting an error:
“expression error: syntax error - extra tokens detected in expression”
The extension I'm trying to save the otl to looks fine, (I'm manually choosing it).
Any ideas? Thanks
digital asset error
10555 4 1-
- Arrev
- 7 posts
- edward
- 8122 posts
- Arrev
- 7 posts
The Houdini console gives this message:
Unable to find dialog script for bridge_asset
at oplib
Sop/bridge_asset?Sop/bridge_asset
After it fails to create the digital asset, I mmb on the subnet and get the error:
“This node is using an incomplete asset definition. asset library containing full function needs to be installed.”
The null (in the subnet) with all my custom parameter controls works perfect. If an expression was not being evaluated correctly on a certain node, would that node show an error?
at oplib
Sop/bridge_asset?Sop/bridge_assetAfter it fails to create the digital asset, I mmb on the subnet and get the error:
- edward
- 8122 posts
- Arrev
- 7 posts
