how to unglue some parts of a glued object
3956 4 1-
- Andrew Graham
- 151 posts
how is it possible to unglue some parts of a glued object? or specificy parts of the object that are not supposed to be glued?
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
- john_z
- 45 posts
you can try to override the glueobject value for those rbd-glue pieces you want to unglue.
Add a RBD State op after the RBD Glue Object, leave the “Glue to Object” field enpty and set the field behaviour
to “set always”, then set “Group mask” to the name of the pieces you want to unglue.
hope this help
hope this help
- Andrew Graham
- 151 posts
sweet so lets say i have pieces 1-10, 11-20, and 21-30 in 3 groups. each of the pieces within those groups i want to remain stuck to each other, but each group i want seperated from each other group. would that work if i just specified the 3 groups, or would that unglue all objects within the group and not just their relationship to each other?
- john_z
- 45 posts
I think that in this case you can proceed in 2 ways
- create 3 distinct rbd glue objects starting from 3 SOPs, partitioning pieces at SOP level
- create a single rbd fractured object and 3 empty rbd objects acting as glues, then set
the piece-glue relationships using rbd state ops.
How your sop is configured ?
- Andrew Graham
- 151 posts
ive just decided to bring in 3-4 seperate rbd glue objects and the sim is working well. thanks.
