H11.0486 crashes loading 11.0.455 files
   2870   4   1
Hi all,
just want to open a file build in 11.0.455 with some old shaders in H11.0486 and after let Houdini update VOPS it crashes with a Segmentation Fault.
Without updating Houdini loads the file fine put Mantra stops with “mantra: Unknown parameter ‘0’” and “UT_NetPacket::read: No such file or directory”
Please, am I the only one? Same machine as always
Thanks a lot for help.
Detlef
Please submit your .hip file
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=15603 [sidefx.com]
Thanks, I've deleted anything with external links, just some old/new shaders and one geo…
Detlef
Balka_tmp3.zip (327.1 KB)
Sorry, I didn't mean attach it here in the forum. I meant to actually fill out the online form and submit it *there*.
Sorry I have not read your text till the end ;o) I've posted it to the online form. But what I've found out is if I delete the only “mantra Surface” shader I took from the Gallery Manager, everything works fine.
Detlef
