how to change the Shadow color
   6947   6   0
Hi there,
i would like to color the shadow of an Object.
How can I go for this in the shader vops?
Any suggestins would be nice.
there are a few ways, but if you want it to do inside surface shader then you can use isshadowray node and change opacity to some color just for shadow rays
here is the simple example
there are also some tips at the bottom of this page http://www.sidefx.com/docs/houdini11.0/light/shadows [sidefx.com]
shadow_color.hip (159.5 KB)
Thanks tamte,
Are there other technics?. I just want that (as example) only the shadows on the floor became green. Taking this approche means that the shadow of the Sphere object is also green on other objects.
A approche based on the object which recieves the shadows and not which casts the shadow.
then you probably need to use illuminance loop inside your shader and alter shadow color there
received_shadow_color.hip (176.1 KB)
Thanks Tamte!
exactly what i was looking for!!!…
please tell me how you learned all this!?
mainly through forums i guess and investigating many examples or native shaders and tools
on the other hand learning is fun so it is quite fast process
Thanks tamte!
