abs() returns all absolute value but is there such a function that returns all negative or make the value always negative? Is there not one because users can simply type ‘-’ infront of any expressions they use?
I scanned through http://www.sidefx.com/docs/houdini11.0/expressions/ [sidefx.com], either it's not there or it eluded me.
Cheers!
eitht.
Q: Expression function that returns all value negative
6955 5 1-
- eitht
- 257 posts
- stevenong
- 1634 posts
- tamte
- 9539 posts
- eitht
- 257 posts
- tamte
- 9539 posts
simple math:
you may be thinking that
1. you have initial transform of 0.85 which is relative referenced parameter
2. on one side you add -4.3 to it in the referencing expression
3. on second side you transform it -6 with another transform sop
4. and yet they both result in the same position (0.85-4.3 == 0.85-6 ?)
but in reality in your file you are not adding -4.3 to 0.85 but to -0.85
so one side: -0.85 + (-4.3) = -5.15
second side: 0.85 - 6 = -5.15
so they are equal and therefore they result in the same position
- eitht
- 257 posts
