Number of frames stored in MDD file
   2668   2   1
I have an object hooked into an MDD point cache file. I'm looking to find out how many frames of animation that MDD file contains. With FBX point cache, I can look at the XML and find that out, but I'm stuck on how to get that info from an MDD point cache.
Any ideas? MDD is binary. Thanks!
Windows 7 64-bit, GeForce GTX 260, 12 GB RAM
If you load the .mdd file in Houdini with a MDD SOP, then middle-mouse on the node, it will give you this info. Or I guess if you ran the “opinfo” on an MDD SOP.
Excellent, that works (opinfo), perfect… Thanks!
