smooth issue
   1891   2   1
i did a simulation using bullet solver.
i am using clustering in the object. The only problem is that I am not able to smooth the edges of the object. If I smooth it,there is a crease in between the pieces glued together due to clusters.
bgeo.rar (4.7 MB)
if you smooth the edges there will always be a crease.. if your just trying to subdivide, increase the crease weight to 10
btw, what skin is that?
this is not a skin. they are suppose to be pieces from broken ground.
if increase the crease value, the edges are not smooth then.
