I play with this great bookasset and wonder how i could propperly handle uv's here. The initial uv setup happens before the main page animation which is done via splines/curves. So when i unwrap the uvs after extruding the animated splines my uvs go off?! How to rest the position here?
Thank you
Lucas
uv rest position
6295 4 0-
- Fest
- 184 posts
- zarti
- 330 posts
hi ,
inside the attached file youll find the procedure i suggest you to replace the polyextrude_SOP which generates the page ..
just copy paste it into your project following two black null_SOPs names .
notes :
– didnt had time to check if anything down the flow gets broken or duplicated . i just UV-ed the pages ..
– also this is a H11 file . hope thats OK .
.cheers
notes :
.cheers
except the things that cannot be seen , nothing is like it seems .
- Fest
- 184 posts
- zarti
- 330 posts
… did you do the original asset ?no
i loaded it a while ago and can't exactly remember where i got it from.search in this forum about ‘page turn’ or ‘book’ .
i remember i have posted once here and once on odForum the link of that fantastic asset .
i found it times ago when i was very hungry about houdini resources and infos on the www .
.cheers and glad i could help
- Fest
- 184 posts
