i am creating a grass chunk generator.
when i try to make it a digital asset, it tells me that there are problem with spare parameters.
The only issue there is is that the ramp aren't working untill i go inside my DA and play with the ramp there…then the parameter outside the DA work again.
it happens often to me with ramp parameter introducing bad node references.
i could never get why it is doing that
creating digital asset issue(bad node vopsop ramp)
6173 8 0-
- sami.tawil
- 172 posts
- edward
- 8126 posts
- sami.tawil
- 172 posts
yes i did, instead of drag and drop, i created ramp parameters and linked them and got the same issue.
i am wondering of the problem is that the parameter are on the object (“geometry”) node, instead of being inside the context as a subnet.
The file is ready you just need to “create digital asset” to see the errors coming up.
…if luckily you find time.
Otherwise for the time being i will just copy paste the tool from file to file.
Also this problem occur often with me when i use ramp in DA…So i am pretty sure the problem must come from me, but i don't know what i am doing wrong
Thanks for answering
- edward
- 8126 posts
- edward
- 8126 posts
- sami.tawil
- 172 posts
i did try the destroy spare parameters, and then the DA doesn't work anymore, lots of function not working.
i get the error when i open my DA…the ramps don't work, so i go in and the info on my pscale attribute says that there is a bad node reference.
anyway i will try to crate de DA without the ramp and add them post.
- sami.tawil
- 172 posts
EDIT: I still have to go inside and move one of the ramp for them to reactivate outside
Also i discovered that the ramp outside don't add points on the ramps inside.
It seems to come from the fact that those parameters are on a “GEO” node instead of beeing on a subnet node created inside the geo.
I guess i will have to redo the whole thing on another level(inside geo)
- edward
- 8126 posts
- sami.tawil
- 172 posts
