Hey guys.
I got a question.
After a few years break from houdini, I am having to relearn a lot of stuff..
One of the things I want to do is lets say I have an object of whatever shape..
I want to use a uv project from the YZ view, and apply a linear gradient to this.
I then want to use this gradient to apply it to an attribute to the surface/points.
The end idea is to use the gradient to drive the scale of copies that are stamped, but in a linear fashion. the gradient will be used for control within the final OTL.
How would I do this?
I imagine that I have to use vops, but if since its been soo long, and it seems like houdini has been re-arranged since I used it ( no longer divisions between sops, vops, chops, etc. I am still stumbling around Smile )
Any help will be appreciated ( btw, still on version 10 of houdini here…. will be getting v12.5 soon hopefully ).
( i moved this post from the learning houdini forum as it didnt pertain to any tutorials )
Linear gradient to objects point attribute
10522 4 1-
- ambient-whisper
- 53 posts
- animatrix_
- 5189 posts
Hey ambient whisper, nice to see you here
Do you mean something like where your copies will have the smallest scale at YZ.min of your template geometry, and max scale at the YZ.max of your template geometry?
In this picture I did the same thing but only for the X axis and I added a small offset to all of them so nothing has 0 scale. If that's what you mean, it's easy to do the same for both axes by repeating the steps and multiplying both before you add an offset.
- ambient-whisper
- 53 posts
- animatrix_
- 5189 posts
By gradient, you mean a ramp? I attached a file showing the same thing but with a ramp. I only did it for one axis, but the idea is the same. Let me know if this is not what you are looking for.
Another thing I assumed was that you needed to do this in the world space. If you want to do this in local space on an arbitrarily oriented geometry in space, it would be more involved if you don't know the orientation.
In that case, these operators would help:
https://www.orbolt.com/asset/animatrix::bestFitPlane::1.00 [orbolt.com]
https://www.orbolt.com/asset/animatrix::computeMinMax::1.00 [orbolt.com]
- ambient-whisper
- 53 posts
Hey, thanks a ton for the examples.
Yeah. possibly a ramp parameter because of its control ability. Its intuitive if exposed.
If its applied to uvs, then no matter where these clouds exist, they will get colour from their ramp parameter in uv space.
The other option I tried is to use an attribute transfer. This option works somewhat but it sucks because it gets it from another object, which I have to manipulate separately, and with less control of falloff.
Another question. Once I get these attributes, applied to the actual object, I know that they can be piped into a number of nodes for specific functionality that is already exposed, but how would I use an attribute as a weight map to drive the scale value Y within a transform node? Do I have to resort to Vops? The only way I have had it work is with a point sop. I have been having issues with getting it to work with vops and the transform node.
What would the expression look like within the transform node? Its not a simple $Cd ( plus some math ) expression. ( I hope its as simple as piping the attribute within an expression. )
-m-k-
