Licensing problems
   5184   3   2
Fedora Core 1
Houdini 7.0.142 for rh9
Everything seems correct, but when I tell houdini to “install a non-commerical …” the error returned (after the agreement dialog) is “Could not generate license key”. I also get the same error from license.sidefx.com.
hkey shows an invalid server key error, but here's the output from the diagnostics:
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Tue Aug 3 21:53:28 2004
Local host name: ragnarok.bolstad.net
Local server code: 1a69d000
Local ip address: 192.168.1.3
License server name: ragnarok.bolstad.net
License server server code: 1a69d000
Server ip address: 192.168.1.3
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: No
License server version: 7.0.142
May modify server from this machine: Yes
License Administrator version: 7.0.142
Http proxy host: (none)
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER ragnarok.bolstad.net ——–
*** WARNING *** - No valid server lines found
hserver -l output:
Hostname: ragnarok.bolstad.net
Uptime: 0:33:02
License Server: ragnarok.bolstad.net
Server Version: sesinetd7.0.142
Version: Houdini7.0.142
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
56 of 501 Mb available
CPU Usage: 15% load
0 active tasks (2 slots)
licenses file:
* Could not open the licenses file. *
There's problems right now with the Apprentice license generator server. Please stay tuned.
Then why don't they just cut out the 30 day license altogether. Seems kind of lame to me.
Uh … this is an old thread ….
