How to select FLIP DOP object from inside Viewport
   2680   1   1
what is the easiest way to select a flip fluid object inside the 3D viewport to be used for Tools from toolshelf that require selecting Fluid Objects…
Everytime I try selecting the object (inside Dynamics Select Mode) it does not recognize my selection and the tool gives me the Error:
“No Fluid object selected”
It does seam to work when I switch to Wireframe mode, but doesn't work when in shaded mode…
Is that by design? does the Dynamics Select Mode ONLY work in Wireframe mode?
thanks,
M.
The easiest way would be to select the actual node, not the object in the viewport.
