Im running houdini on osx 10.8.2 and i have problems with creating certain characters.
Biggest problem is that i cant create “$” character, so ive ended up copy pasting it from outside of houdini. Not very convenient.
It seems that none of the “Alt+” characters dont work.
Im using finnish layout but changing to uk layout didnt solve it either.
Has anyone had similar problems?
thanks!
Kustaa
keyboard issues with OSX
3456 4 0-
- kustaa
- 47 posts
- anon_user_37409885
- 4189 posts
- kustaa
- 47 posts
- Cyzor
- 181 posts
Houdini doesn't seem to like the option key modifier for some text fields. You may want to try some third-party software that can remap one key to another:
KeyRemap4MacBook (works on any keyboard, despite the name):
https://pqrs.org/macosx/keyremap4macbook/ [pqrs.org]
Keyboard Maestro:
http://www.keyboardmaestro.com/ [keyboardmaestro.com]
I thought another solution might be to edit your global keybindings to automatically insert the $ symbol when you type some other key. Although many applications honor the change, Houdini 13 generally does not.
Houdini also seems to ignore the substitutions defined in the system Language & Text preference pane.
Keyboard Maestro:
- kustaa
- 47 posts
