Does anyone know why Houdini does not work with Windows keyboard shortcuts?
Alt F4 - typically closes a window. Sometimes escape works for this. Can I map a key to close a window (softimage had the same problem).
Alt Space + M or X - minimises or maximises a window.
Ctrl N - new scene is Alt+N in Houdini which does not work (it brings up a dialogue window which does nothing.
Lee
3705 2 0-
- LeeGriggs
- 3 posts
- Doudini
- 333 posts
you cant use these shortcuts. they are outdated windows specific shortcuts and houdini wont accept them.
alt n is working here.
to close a window/panel in houdini use ctrl w. (works in explorer too)
to maximize window: windows key + up
to minimize windows key + down
in general you should probably switch to use windows key to manage your windows etc.
there are some nice shortcuts:
http://windows.microsoft.com/en-us/windows/keyboard-shortcuts#keyboard-shortcuts=windows-7 [windows.microsoft.com]
you also might want to try out linux where you can pretty much custom map everything.
cheers.
cheers.
- LeeGriggs
- 3 posts
Outdated? Every Windows program uses them.
It brings up the window but can you click on the options?
This doesn't work for any windows I tried in Houdini. Which ones does it work for you?
Tried that before. It was a mess.
