Crash report Houdini13+openVDB dso's
   2782   1   1
I get this crash report when trying to use the OpenVDB dso's from the OpenVDB houdini kit. My system is Linux Manjaro 0.8.10
Crash happens when i show the Detail panel, or with executions of some nodes.
I guess I did some compiling wrong.. :\ i will try to compile it all again, but maybe some one here can understand the error log. He\she will be my savior!
Crash report from arojtblat; Houdini FX Version 13.0.401
Traceback from Wed May 28 19:34:23 2014
Caught signal 11
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler:perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
killpg <libc.so.6>
SOP_OpenVDB_Read::cookMySop(OP_Context&) <SOP_OpenVDB_Read.so>
SOP_Node::cookMe(OP_Context&) <libHoudiniOP2.so>
OP_Node::cook(OP_Context&) <libHoudiniPRM.so>
OP_Node::internalCookInput(OP_Context&, int, OP_Node&) <libHoudiniPRM.so>
OP_Node::lockInputs(OP_Context&) <libHoudiniPRM.so>
SOP_Node::lockInputs(OP_Context&) <libHoudiniOP2.so>
SOP_Script::cookMySop(OP_Context&) <libHoudiniOP2.so>
SOP_Node::getCookedGeoHandle(OP_Context&, int) <libHoudiniOP2.so>
JEDI_View::updateWorkbenchGeometry(bool) <libHoudiniAPPS3.so>
JEDI_View:puiUpdateNodeInfo(OH_NodeInfo*) <libHoudiniAPPS3.so>
OH_OpHandler:puiUpdateData() <libHoudiniUI.so>
OP3D_View::doUpdate() <libHoudiniAPPS3.so>
JEDI_View:puiUpdateData() <libHoudiniAPPS3.so>
OH_OpHandler::trigger() <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
_start <houdini-bin>
Extreme Thanks
I replied on the openvdb forum.
http://www.openvdb.org/forum/?place=msg%2Fopenvdb-forum%2FLi5bKA2zj7U%2Fo2u-zPWaUnYJ [openvdb.org]
