Hi
Is this working , or we need to do some “trick” in asset , like for particles , where we need vopsop , to move particle with velocity in between frames.
I see asset creates , some velocity conversion node , and i can see velocities in viewport but not in render.
When i put whole frame MB , arnold caculate some motion blur , but i don't know this is correct mb or not.
Also i tried puting timeblend node in asset , but this crash arnold.
Volumes Motion Blur?
8885 3 2-
- Radovan Milosevic
- 8 posts
- awong
- 818 posts
I assume you mean motion blur for fluidShape, since Houdini's volumes are brought into Maya as a fluidShape. The velocity volume from Houdini is mapped into velocity grid in Maya's fluidShape. So if Arnold can use the velocity grid to create motion blur, then it should work.
I don't know what kind of motion blur support Arnold has for fluidShape though. Does motion blur work for native fluid that's simulated in Maya? I'd recommend doing a simple test to verify that it works for native Maya fluids, then do a similar test for Houdini Engine.
Andrew / アンドリュー
- -heavy-
- 62 posts
as far as i know we are all here with Maya waiting for MotionBlur on Fluids
movement. we have motion blur on a moving Container and camera motion blur.
but not on the movement of the fluid itself
ohh and i am on MtoA 1.1.03
Janko Kissel
Maya & Houdini Smoke and Demolition VFX-Artist
http://vimeo.com/heavyatvimeo [vimeo.com]
https://www.youtube.com/user/masterheavyone/videos [youtube.com]
- awong
- 818 posts
