How to fix Polly squares on geo?
   6133   5   3
Hey guys, I am trying to export an LSystem with metaballs and I can't seem to get it right…
How can I get rid of the pollys for a more smooth surface, and yes I have used smoothing.
NormalSop and use a large angle 89.
sl0throp
I am using Houdini 14, I don't see normal sop.
thanks for the reply
Okay, I am stupid… Sop is a node…
Okay so I have that hooked up and it's not doing much?
try a few things:
- make sure the normal sop is set to points and not vertex
- try adding a fuse SOP to connect points (I cannot remember what convert meta actually outputs.. if you middle mouse, is it a polygon?)
-G
you need to apend/place a convert node before the normal sop
set it to convert to polygons
then you can get the “soft” normals you're looking for
