Extrude tool
   2335   2   1
Hi! Please help Have problem with another commonly used tool in box modeling. I tried tu use both Local and Global modes and translate by different axis and scale. I need to extrude geometry so that it will has thickness. Not as here
https://drive.google.com/file/d/0BxyYG9AZ78ZpcTBIczUtbmhLcEU/view?usp=sharing [drive.google.com]
but as here
https://drive.google.com/file/d/0BxyYG9AZ78ZpUlFzLXlTampQOEU/view?usp=sharing [drive.google.com]
and this little floating window (it seems to me it was added to the latest Maya version) with main parameters is very convenient, it dissapears after operation is released (you can define parameters later in the Channel editor (at the right side) which is similar to Parameters editor), and it would be so handy to have something like this floating window in Houdini
And on the orthographic views grid lines are wider than wireframe lines of an object and I can't find in settings how to fix it.
And remembered one more thing > if I have points that are not lie on the one line and I select them and want to snap to the grid line > they keep spacing between them. How to avoid it to make them all snapping to the line?
Thanks for any help … and even reading
Go to the PolyExtrude Options tab and switch on Output Back.
Werner Ziemerink
Head of 3D
www.luma.co.za
Thank you, Werner Ziemerink, you helped me a lot
