Houdini Apprentice won't start
   12503   7   0
Max OS X 10.11.2 El Capitan
Installed Houdini Apprentice but it says “No valid licenses where found”. And I see the Server “is not running”.
Tried the Sudo command:
sudo launchctl load /Library/LaunchDaemons/com.sidefx.sesinetd.plist
However it just returns this line
/Library/LaunchDaemons/com.sidefx.sesinetd.plist: Service is disabled
MacBook-Pro:~
I suspect that Houdini is not yet available for this version of OS X but maybe you fine folks know better. :idea:
When you install Apprentice, don't install the license server, choose the other option (which is for free usage).
Also, on OSX, the very first time you run Houdini your OSX user account must have administrator privileges or the license files can not be written to the user name correctly.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Thanks Enivob!
Well I uninstalled Houdini and reinstalled. The installer isn't very clear on what I should do to get Apprentice working. I deselected the license server.
Still having the same issue… I am indeed the administrator on this computer. Not sure what to make of this.
Screenshot 2015-12-13 16.45.45.png (209.2 KB)
Choose Local Licensing for Apprentice which will turn off the other licensing option.
That worked! Thank you!
If I end up buying Houdini Indie will the fact that the regular license server refuses to start be an issue?
Thanks again.
Enivob
This is incredibly helpful! We didn't know about the admin-privileges requirement when the License Administrator is installing a license. If you don't have that privilege, it gives a completely un-helpful error report , like this:
Once installed, the license is usable from any account on that machine.
We're trying to teach a class involving Houdini, and some of the students had mysterious problems. This looks to be at least one of the causes. Enivob, you are a lifesaver.
So to be clear, to run the apprentice version,
A) You have to use the OLD installer, the new one doesn't give you options as above
B) Do NOT install the license server
C) Do NOT install the HQserver
D) Install as admin
Unclear to me:
"Choose Local Licensing for Apprentice which will turn off the other licensing option."
What does that mean? It's ambiguous Tell me which specifically box to check for that. Thanks
Is this correct?
So none of that works. I've never had such an issue getting a software to launch. It's ridiculous. What am I doing wrong?
Screenshot 2025-12-21 130043.png (22.0 KB)
