Bind Exported Attribute Not Showing In Geometry Spreadsheet
   3212   2   2
Hello everyone. As expressed in the title, that's my problem. I'm kind of new to Houdini. I have my color input connected to a fit node, then converted to float value, and when I connect that node to my bind export, the attribute does not appear in the spreadsheet. I don't know if it is just a silly UI thing that I did not check, or if the attribute is not being exported at all. Just so you know, I'm following some tutorial about a melting angel, which I heard was a good place to start, along with the side fx ones; maybe that helps.
Thanks in advance, and sorry for my crappy english, if so.
Cheers.
Sometimes panels get ‘pinned’ (see the screenshot), so they don't update to the current node. Or maybe you're looking at the wrong class of attribute in the spreadsheet? I assume you're in a Point VOP?
If you're able to share a hip file, that's always helpful.
I'm o.d.d.
goldleaf
That was it, thanks so much for the quick answer!
Cheers.
