couple of month ago H showed my the asset name and path of it in each node. Cant remember how to activate that. Or was it a asset?
Thx in advance.
Cheers
Showing asset name and path
9730 4 2-
- Follyx
- 237 posts
- rvinluan
- 1302 posts
In the Houdini main menu bar, select Windows -> Operator Type Manager.
Then in the popup dialog choose the Configuration tab and change the Operator Type Bar drop-down menu to “Display Menu of All Definitions”.
Now when you select your HDA node you will see the asset name and path in the Parameter Pane.
Rob
Rob
- Follyx
- 237 posts
- kevin_ess
- 9 posts
This has changed in later versions. As of Houdini 19 (and maybe some earlier versions), it is now found here:
Windows > Asset Manager
then inside this window, you will see two tabs at the top: Operators | Configuration
Click on Configuration tab.
Near the bottom of this tab, you will see "Asset Definition Toolbar:"
Select "Show Always."
Edited by kevin_ess - Nov. 5, 2021 17:14:36
- daveborck
- 35 posts
