Cutting a mesh into pieces and saving each piece
   5424   1   0
Hi.
I was hoping to get a little bit of help with a project I'm working on. The goal is to split a piece of geometry into smaller pieces and saving the pieces to disk.
This is what I have so far:
I can use a group node with a bounding object input to select the points within the box and blast away the un-wanted points.
I can use a grid object to make points at the correct location and a copy node to place boxes on the grid.
What I'm hoping to learn is this:
* iterate over each one of the boxes that were created via the copy node on the grid
* Cut the selected piece out of the input geometry
* move it to the center and then save out as an unique obj file to disk.
-Gisli
see attached, uses box_id == $F to iterate…
cutter.hiplc (84.8 KB)
