Is there somewhere more documentations and examples about the UI Script Language ?
I only know about this sidefx doc page (cf. Houdini User Interface → The .ui Script Language [sidefx.com]) and the good huilib user's Python library (cf. odforce post [forums.odforce.net]).
Do you know if that's possible to make a custom popup menu interface in this language, instead of pyside, for a better visual (and design possibilities) integration ?
Thank you.
UI Script Language : more doc ?
2922 2 2-
- julca
- 271 posts
- _Christopher_
- 767 posts
- julca
- 271 posts
Hello Christopher,
Correct me if I'm wrong but I'm not sure that I can build custom menu with HScript.
And the HScript doc explicitly recommend to use the scripting API (Python) instead.
So that's probably same thing with the UI Script Language..
(shame because at least the design interface is the same as Houdini with this language..)
Anyway, I'll go with Python GUI.
(shame because at least the design interface is the same as Houdini with this language..)Anyway, I'll go with Python GUI.
