Similar Primitive selection
   3322   2   0
Hi
Is there any way to select similar primitive? For example i have a box which has 10 primitive on each side and i want to select three specific primitives from all sides but i dont want to go to each side one by one and try to select the same primitives. Is there any quick way to select same primitive of all sides?
In your cube example you can double your selections by turning off Select Visible Geometry Only (the eye icon). This will cause your selection of faces on one side of the cube to pass through to the other side thus cutting your selection work in half. But that really will only work with your cube example.
Houdini selection is quite robust, if you have not watched the Go Procedural how-to selection video on Vimeo, head over there and check it out.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks Enivob for your help this is exactly what i want
