Dynamics Quickstart tutorial: small problem
   4940   1   0
All:
I'm having a slight problem with the Dynamics Quickstart tutorial - it seems that when I get to the section where one has to copy a piece of the vase out of the simulation, I can't seem to find the vase piece anywhere. /obj/rbd_dopnet:vase4/Geometry doesn't even appear in the object hierarchy. If I pull up a Choose Operator: dialog next to Object 1, I can't find the vase underneath rbd_dopnet either.
How would I go about taking the piece of the vase and putting it into the Object Merge node?
- Brian
You have to type the string specified in the tutorial into the Object Merge SOP manually. DOP objects do not appear in those node browser trees (because DOP Objects are not nodes). There is already an RFE to add DOP objects to that browser, but we didn't get around to it in time for the H8 release.
Mark
