Issue with fuse node
   2715   2   0
I'm have issue with the fuse node, so I have curve and used the sweep node to create boxes along it to make a path but I'm unable to fuse the vertex with the fuse sop could anyone let me know what I'm doing wrong? Iv attached a sample of the issue I'm having. The fuse is connecting the points but it is not merging them.
issue.hipnc (126.2 KB)
Fuse is used for points not vertices.
http://www.sidefx.com/docs/houdini/nodes/sop/fuse [sidefx.com]
Why are you wanting to ‘fuse’ the vertexes?
They are needed to define each individual box(primitive) along the curve.
http://www.tokeru.com/cgwiki/index.php?title=Points_and_Verts_and_Prims [tokeru.com]
Are you wanting somehow for all the boxes to become one single primitive?
Edited by BabaJ - April 23, 2017 15:11:03
I'm sorry I used the wrong terminology, but yes essentially I want all the boxes to become one primitive. I tried to use the poly extrude with the box instead but I was not getting good results
