Output logs for UE4/ Houdini Engine?
   4326   3   0
I'm wondering if there are any advanced output logs available for UE4 / Houdini Engine?
I'm new to Houdini and I'm learning about using it in UE4, I'm getting some weird behavior when I use my asset in UE and was hoping there were some more verbose logs.
Cheers for any help or a point in the right direction.
Dave
Hi Dave,
When something strange is happening and you want to debug what's happening in Houdini, the best way is probably to open the internal Houdini scene used by the plug-in.
This will allow you to see exactly what is Houdini doing with your asset in Unreal, and debugging should be way easier this way than through log.
To do so, simply do File > Open scene in Houdini.
I'll give that a go, thanks for the info.
Dave
Houdini Session Sync
Artur Mandas
Artist & Developer
http://arturmandas.com [arturmandas.com]
