Hey all,
I prefer doing my modeling in Wings 3D and I was curious if it would be possible to import models into Apprentice for rigging, animating and rendering using the .obj file format.
Does Apprentice support obj file import?
12499 6 0-
- draz
- 11 posts
- lucas
- 269 posts
- draz
- 11 posts
- draz
- 11 posts
lucas
Yes, obj models should be supported to some degree. You can load in the model with a File SOP.
I've been trying to import an obj file using the file SOP into Apprentice with no luck. I'm getting an error in the network that says Houdini is unable to read the file. Do you only need to add the File SOP and then navigate to the obj file to import it or are there any other steps necessary?
- lucas
- 269 posts
Are there any spaces in the file name or in the path to the file? I'm told Houdini doesn't handle spaces well in the file sop.
If the path seems okay, then I guess Houdini isn't able to read in that obj file. Is it a nurbs model or a polygonal model? Does Wings 3D let you save out IGES files? If so, you may have better luck loading an IGES file into Houdini.
- edward
- 8115 posts
- draz
- 11 posts
