Hi there!
I'm new in Houdini, using now Houdini 16 Apprentice. I think my question may be very noob but I really don't find an asnwer.
I'm doing a Flip sim with the shelf tools. Just a flip tank and an animated sphere as static object. In the Collision Source node of the sphere I'm using velocity with central difference. The problem is that in the geometry spreadsheet, the value of the v attribute is 0, in x, y or z. Seems that velocity is not influencing my sim.
How to compute velocity of the sphere (or any other collision object) in H16 to have an impact in the fluid?
Thanks in advance!
Flip Fluids - Collision object velocity is zero
2925 2 0-
- Cristian Andrade
- 2 posts
- Enivob
- 2659 posts
Recreate your scene but instead of choosing static object for your sphere collision use Deforming object. Or dive into your existing AutoDopNetowkr and select the StaticObject node. On the StaticObject node enable deforming object and or inherit transform. It depends upon where you have animated your sphere. Standard Houdini practice is to NOT animate at the top level. Instead drop down a Transform node inside the Geometry node and follow that up with a Trail set to compute velocity. Animate the Transform node inside.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Cristian Andrade
- 2 posts
