Poly Extrude Direction/Normals problem/bug ?
   4748   2   0
Hello, i'm doing small projects, and stumbled upon weird behavior in Poly Extrude SOP.
In picture below, i have grid, rotated grid #1, i'm fusing points “Consolidate”, setting normals in Wrangle “@N = {0,-1,0}” #2,
and PolyExstrude SOP #3 does not give a damn about normals direction, and fuse SOP, and extrudes everything with those two grids settings from far above, do you guys know why is it happening ?
the primitive normal is based on the winding of the polygons, not any attribute. You probably have backwards polygons. The reverse tool can reverse the winding of polygons.
Thank you, that helped
