Flowmap Guide SOP issues with subdivision
   2141   1   0
Hi all,
I am using here the flowmap guide sop it is working great! Thank you to the Houdini team for this awsome Game Tool Set.
One issue what I have with the flowmap guide sop is, if i am doing subdivision on the surface the flowmap guide sop will break. Even if i am freez the subdivison the flowmap guid will not more work.
If I am using the combo sop to paint the flow by hand, this is working for both.
I checked the primitve, point orders they are changing with the subdivision, i try them to fixed with the sort sop, it was not working.
Maybe some one can help me from here?
Cheers
Emre
FlowMap_Subdivison.hip (2.0 MB)
Hey there,
Thanks for using the tools! However you are using some quite out of date tools, if you're on Houdini 16.5 you can use the shelf to download the tools.
The Comb is based on point numbers, so that's why subdivision will break it, the Flowmap guide should work throughout the subdivision process though
Luiz Kruel
Senior Technical Artist
