License manager crashes using ATI Open GL drivers
   8838   9   0
when i try to inastl licenses on my comp i get this error. Any help is appreciated.
Error Signature
AppName:hkey.exe AppVer:8.0.0.474 ModName:atioglxx.dll
ModVer:6.14.10.5696 Offset:002a1481
System Information
Time of this report: 4/7/2006, 17:59:58
Machine name: P4-ASSASSIN
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: VIAK8T
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon™ 64 Processor 3000+, MMX, 3DNow, ~2.0GHz
Memory: 768MB RAM
Page File: 527MB used, 1344MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: RADEON X700 Series
Manufacturer: ATI Technologies Inc.
Chip type: RADEON X700 PRO AGP (0x5E4B)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5E4B&SUBSYS_23021002&REV_00
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6601 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/21/2006 22:46:46, 256512 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 2/21/2006 22:46:25, 1505792 bytes
Device Identifier: {D7B71EE2-1D0B-11CF-7B6A-0803A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5E4B
SubSys ID: 0x23021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)YUY2,YUY2) Frames(Prev/Fwd/Back)0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)YUY2,YUY2) Frames(Prev/Fwd/Back)0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)NV12,0x3231564e) Frames(Prev/Fwd/Back)0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)NV12,0x3231564e) Frames(Prev/Fwd/Back)0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)NV12,0x3231564e) Frames(Prev/Fwd/Back)0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)NV12,0x3231564e) Frames(Prev/Fwd/Back)0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
So if you try to even open up the License Administrator (via the Start menu), it crashes? Where are you getting all this output from?
It crashes when i try to enter a license. I got my system info from dxdiag and the error info from the “do you want to report to microsoft” dialog box.
Are you not connected to the internet? Just run Houdini Master from the Start menu. A dialog should come up. Click on the link to install a non-commercial license. If that doesn't work, are you able to start the License Administrator and choose View > Diagnostic info?
I have the same problem for on my Macbook Pro, it crashes regardless of it is connected to the internet or not.
/oskar
Ok Just Read Care Fully What i am gonna tell you people
1=Open the Windows folder and find the file name “ atioglxx.dll ”
2=When you have the file just move it from its current position to any other folder or rename it or whatever you want BUT DON'T DELETE IT….
3=when you don with the file “ atioglxx.dll ” just run Liecence Admin and do whatever you Need.
4=When you don with Liecence Admin just close it and Restore the file to its origional path you just rename or moved or whatever you don with it anyway the file name was “ atioglxx.dll ”
5=Have Fun…..
Another Way is just you have to do is remove your new or currently installed drivers and find your self ATI Drivers OLD VERSION or the CD that just Came with your Card (just don't use new Driver Version ) then run the Liecence Admin and it'll work fine when you don with lience Admin just close it and use your New Drivers and upgrade your Driver Version.
Have Fun
anyway just let me know if it helps you …
Regards
ALi 8)
Errr… ATI.. I've had similiar problem to yours. When I was starting Houdini, license dialog came up and its window was black except one button(I think it was cancel) and window's name. Wow. What a description . I can reproduce it and post screenshot if anyone is interested. I tried installing older drivers, even that old one which came with my radeon. Nothing helped. So I installed new drivers. Still nothing. So I tried turning few things off. And guess what. I turned off one program and started up Houdini and hey, it was OK .
Oh, and by the way it was ATI Tray Tools program from windows tray bar(is it what is that called? You know, that space in lower right part of screen )
Too True T-bat too True.
its one more tip to those they just facing probs with ATI
I've ATI AX 600 Extreme and it also gave me Problems so what if can bought houdini so why can't i bought a new N-Vidia Card huh now ATI is in my Junk Strore & My Assitant will use it & i have Nvidia 6800 PCI Express its Working fine (but i think ATI can only work in 3d Games or with nothing)
Believe me i am realy not gonna buy any product of ATI in future…. Company is shit they even did'nt helped me or did'nt realeses any bug fixes.. :x
and even there are mess of difrent ATI Drivers & Whom to Believe or What to do …… Realy Hate it
Not just the licence manager but any other floating panel in houdini will cause problems.
If you have a dual monitor setup just turn the second monitor off.
Then if you want go guru3d.com to mod your card to a firegl.
check my post:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=6364 [sidefx.com]
Live life in chunks.
