Can't select point under mouse cursor
   2716   2   1
Hi everyone,
I'm coming over from Maya and have just downloaded Houdini Apprentice. I am following along with the Houdini Foundations PDF, and every time I try and select a point in Houdini, it doesn't select the point under my cursor, but rather some other arbitrary point on my object. I've tested this with the soccer ball we create following the PDF, and also just a subdivided cube. On the cube I noticed I can select corner points, but if I try and select any other point, it will select the wrong point.
The uploaded picture shows the issue, the screenshot doesn't capture my cursor so I've circled in red the point my cursor was hovering over, and you can see in blue the point Houdini has selected.
Kind Regards,
Kaine
Hi! This is apparently fixed in a recent daily build. Could you try installing 16.5.483 or later from https://www.sidefx.com/download/daily-builds/ [www.sidefx.com] and see if that fixes it?
I installed 16.5.485 and that did the trick! Thanks!
Edited by Kainev - May 28, 2018 12:00:10
