attribute values and font
   2494   1   0
Hi, I have a question, if I create a float attribute, or I modify any parameter and set its value to 1.1 for example, and then I create a FONT and then add the value to the font display text, it shows something like 1.100000000000000001, is there a way to show exactly what I type on the value?
Use a string attribute instead.
in a wrangle you could do:
s@value_str = sprintf(“%0.6g”, f@value_float);
and then use this string attribute in the font instead of the float attribute.
format_float_string.zip (13.6 KB)
