Clear selection
   2489   1   1
How can I clear the node selection so when i create a playblast i do not have the selection brackets visible? I do not understand why i keep getting this error:
import hou
hou.Node.setSelected(True, clear_all_selected=True)
TypeError: unbound method setSelected() must be called with Node instance as first argument (got bool instance instead)
Additionally how can i set the selection mode to Box Selection using python.
As the error says, you need to call the setSelected method with a node instance as first argument meaning
mynode = hou.node("/obj/mynode")
hou.Node.setSelected(mynode, True, clear_all_selected=True)
or
mynode.setSelected(True, clear_all_selected=True)
Hope it helps
Cheers
-J
