Houdini 16.5. I cannot import a lidar data from a file. Here is its format
493262.188 7533653.616 348.168 73 76 70
that is
XYZ RGB
Please, tell me how to work with such arrays. I used Lidar Import, but it has some restrictions of supported formats. As I understood, I need to realize a reading this file myself. How does it work? Thanks.
Import Lidar data with XYZRGB-format
2504 1 1-
- 4df85cd2afda4051
- 1 posts
- neil_math_comp
- 1743 posts
If it's just simple tabular data you might be able to use the Table Import SOP, or if you need fancier options, you can use the Load Data Table (https://www.orbolt.com/asset/ndickson::load_data_table) asset from Orbolt.
Edited by neil_math_comp - Oct. 10, 2018 13:55:31
