Issue when updating Game Dev Tools and using Simple Baker
   2829   0   0
I am having the same issue as: https://www.sidefx.com/forum/topic/53282/ [www.sidefx.com] - where I have an error as I try to update the game dev tool shelf, so I manually installed it.
But the Simple Baker now don't work.
It gives me this error on a simple box bake (which works on my Houdini at work, but not at home, even tho I copied/pasted the GameDevTools themselves to be sure I use the same…)
Thank you.
Update error: Traceback (most recent call last):
File “update_toolset”, line 118, in on_updatebtn_press
File “update_toolset”, line 292, in on_dialog_close
File “update_toolset”, line 206, in download_url
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.173/python27\lib\ntpath.py”, line 85, in join
result_path = result_path + p_path
UnicodeDecodeError: ‘ascii’ codec can't decode byte 0xe8 in position 18: ordinal not in range(128)
Simple Baker error:
