Houdini Vellum weld (or other constraints) and Struts
   2084   0   0
Hi
I am very new to Houdini and just started using vellum to make a pillow as a test. I made it quickly in Marvelous Designer 2 pieces of cloth (square) with overlapping points from MD. I bring the geo into Houdini and use the points on the 2 pieces of cloth and weld (vellum) them together. After that I tried using the struts vellum node but it won't change the shape, it think its because I am using points to weld ( used edges as well but no luck) and its treating it as 2 meshes?
the only way i can get the struts to work is by fusing the seam edge on the pillow. Is there a way in Vellum to join the points and use struts without fusing the geometry.
I am only working in the SOP network, still learning how to use the other networks.
Imran
