How to change viewport colour of objects.
5719
7
0
- isamarsh
- 12 posts
Any way to do this ? I know you can change the wireframe, but the shaded color seems to fixed to grey.
- malexander
- 5301 posts
You can append a Color SOP to the geometry instead if you want to do it on a per-object basis.
- isamarsh
- 12 posts
No clever way to do it at the OBJ level or even better at the Network Box level ?
- malexander
- 5301 posts
Other than assigning a material at the object level with the desired color, no.
- isamarsh
- 12 posts
Ok, thanks for clearing that up.
- ryuku
- 171 posts
may it happen you're looking for D > Material > Default Material
- raincole
- 711 posts
isamarsh
Actually yes. Parameter Pane -> Options (gear icon) -> Add Visiualizer.
Then add a constant or random color at detail level.
- coccarolla
- 165 posts
isamarsh
How can you change the wireframe color in the viewport per object at sop level!?
