Can not find my houdini.env folder
   5808   5   0
Hi i have the houdini apprentice license and i would like to install the redshift on it. I have been looking tutorials and reading some posts but i can not find my houdini.env folder. It is not on the folder of my Houdini and i dont know why.
Do I need to ¡buy houdini in order to be able to see that .env folder?
Thank you.
Edited by ixXe - May 6, 2020 13:47:11
houdini.env is a config file inside your Documents/houdini18.0 folder.
( If it's not there, then just start Houdini and it will create everything )
But you won't be able to use RedShift with Houdini Apprentice though, since 3rd Party Rendering is not supported:
https://www.sidefx.com/products/compare/ [www.sidefx.com]
Edited by blackpixel - May 6, 2020 18:23:07
to expand on blackpixels post: if you did a “normal” install of windows and Houdini you will find env file at C:\USERS\your account name\DOCUMENTS\HOUDINI18.0
it will be in that root directory
blackpixel
ooh i did not know that. So ill need Houdini Indie in order to be able to use redshift. Thank you!
bobc4d
And i think I did a normal instalation, but as you can see, my ENV file is not there.
Maybe it does not appear on the apprentice license.
You can check the “Help” menu -> “About Houdini” -> “Show Details” -> Make the window bigger and scroll down to environment.
These are your active env variables for your current Houdini session.
There should be a HOUDINI_USER_PREF_DIR, which is where the treasure is hidden.
