Vellum spin
   4491   3   2
Is it possible to animate the rotation of a vellum constraint?
I have not been able to use rest vector.
example: a rotation of the pyramid around point 1
Edited by Poulpito - May 9, 2020 06:20:49
ex.hipnc (489.2 KB)
Hi!
Since soft bodies do not have rotational velocity (It don't make sense) like w in rigid body dynamics, you should create rotational force yourself.
See the HIP file.
Hope it helps!
ex FIXED.hipnc (525.6 KB)
Poulpito
only thing you need to do is make sure your pins have Match Animation On and just animate p@orient attribute
ex_mod.hipnc (496.0 KB)
Thank you
@N-G There is a rotation velocity in Vellum, the problem is that they conflict with the bend of the hair constraint.
@tamte The objective is to have not pin, the system must come free on each side of the motor.
