Hi!
Do you know if editableStage method can be used into HDA python module?
When I use it always returns None…. and EditTarget with the active sessionLayer is not an option because creates unexpected behaviors with the layers.
Thanks in advance.
Solaris - editableStage method into HDA returns None
1369 1 0-
- dbastidas
- 2 posts
- LeoEvershed
- 6 posts
I had the same issue.
If you look at the LopNode [www.sidefx.com] you'll see that the editableStage() function is under the heading "Python LOP Scripting Only" meaning those functions only work when using the Python Lop node.
If I find a solution to my specific problem I'll post here in case it's relevant to others.
