Vellum drape seam problem
   2471   1   0
Hi
I have an odd problem with the vellum drape node.
I am trying to weld 2 groups that have been created using a fixed number sub-div curve.
The number of sub-divs have been set to 6 on both curves.
I would expect 7 connections to be made but only 5 is created, and they are weirdly distributed along the curves.
If you count the points in the mesh there are 7 on both.
The patches are made from merging several curves, that have fixed subdivisions and passing them to the Planar Patch from Curves with Resample Curves turned off.
I have no idea what I might be doing wrong here?
obviously, points order don't matchup.
here's an illustration i did awhile ago, a bit old…but you CAN manually type in pairs of numbers
if you can be a$$ed
other than that how are ppl gonna help without your file?
