Help! Somehow the geometry SOP turned into a hda!!
   2835   2   0
Somehow the default geometry node has turned into a digital asset and it causes major problems, because all the geometry nodes inside my other hda's are converted into this one erasing what was inside them.
Cheers
Edited by JacobAndersen - Aug. 27, 2020 02:43:41
I solved the problem… I have no clue how it happened though.
I deleted the file OPcustom.hdalc in the otls dir.
JacobAndersen
usually by accident
RMB/Type Properties… -> Apply or Accept
I think it happened to most people before, either with geo, subnet, merge or any other essential node
strangely noone ever seems to have a clue how that could have happened, lol
instead of blasting the whole OPcustom.hda you can use Asset Manager to just remove the definitions you dont want in there, in case you already have some other hdas stored in that library
Edited by tamte - Aug. 27, 2020 13:32:47
