Load animation from sequence of meshes + list of times
   809   0   0
I have a sequence of .obj files, and a list of times in a text file. I would like to turn each mesh into a keyframe at the specified time, i.e., all of the point positions in the i-th mesh are where those points should be at the i-th time in the text file.
What's the best way to do this?
I see that I can create a channel for each point's XYZ coordinates, using the Geometry node inside a CHOP. But then how do I populate the channels with data imported from the mesh sequence?
