Import mesh have a visual problems
   1667   0   0
Imported fbx mesh in houdini. Some parts are transparent, but close up you can see a transparent texture. In Maya and in other programs, the mesh is visible perfectly. What could be the problem? Only the base color is used for textures. I tried to fix the problem with node clean, doctor poly, but it doesn't work.
