Applying generated textures to material instance parameters
   2432   2   0
For some reason I'm failing to set a texture parameter in a material instance inside UE with a texture that's generated by Houdini Engine. Following instructions in https://www.sidefx.com/docs/unreal/_materials.html [www.sidefx.com] I've managed to create a material instance and can also set the instance's texture parameter with a texture that's already inside UE. Generated textures also work perfectly fine when I use a fully generated material as well. I also can set a non texture parameter just fine too (for example a color vector). But however I might try I can't make a generated texture to be set inside the parameter of an instance. There are no warnings/errors, just no result whatsoever.
My setup is as follows: there's a cop2net that generates an image (using Substance) that's then referenced by a principal material. That material is then set to the geo after which I create two primitive attributes. All of that is inside a digital asset.
Please refer to the attached Houdini screenshot to see that setup and the attribute that I try to use for the material parameter. The UE screenshot shows the result of that asset. There you may see Houdini Engine generating a material that uses the texture that was setup inside Houdini and a material instance where I want that texture to be used as well (instead it uses the default one I set in the material itself).
Would appreciate any help with this.
You may notice that the attribute type is set to Point instead of Primitive or Detail. Setting it to the proper type still produces no result.
Solved the issue. The attribute's value should be "matnet1/principledshader1/diffuse" (without quotes).
