Line sweeping along a curve
   6603   9   3
Hey guys! I have a question for you. I'm trying to get my line to sweep across this here curve. (the end result being a soulercoaster for games).
Currently this is the setup I have. I'm trying to make the line/mesh have a falloff to a point.
As you can see here, For some reason all the vertices are getting compressed on one side.
I was expecting the shape to look like this.
I was followign a few tutorials, but those seem to be outdated at this point. Any help would be super appreciated!
http://paulmillerart.com/ [paulmillerart.com]
maybe it will work already, if you interchange the inputs, and you can also move the line more to the center.
You just need a single Line and a Sweep.
Edited by eikonoklastes - Feb. 7, 2021 01:49:40
Screenshot 2021-02-07 104211.png (182.9 KB)
Hey guys! Thanks for the assist.
Aizatulin
To your point. I did put the line in the center before, and that didnt work like I thought. I also switched up the inputs, and this is the result I got.
As for using a single line and sweep, that does part of what I need it to do, however, HOW it's not following along a curve like I'd like.
You can see the curve off here to the left
So I think I "figured" out a solution?
I copied a few cubes to the pts as you see here.
Those points are generating curves like so.
The thought was. I could extrude my geometry along the curves. However this is the result I'm getting.
As you can see here, it's not following the curve.
I feel like I'm doing something very incorrectly.
The backbone should be the left input, here is an example and yes the second input is optional.
sweep_line.hipnc (84.9 KB)
Well that works, but that's not exactly what i"m trying to do.
This video is a way more accurate representation.
https://www.youtube.com/watch?v=DDuiLJ0LGqM&pbjreload=101 [www.youtube.com]
Edited by Pmiller001 - Feb. 8, 2021 12:46:53
AFAIK is polyextrude only working on single curves as second input, but using a feedback loop can help you to avoid this restriction. Here is a simple example using id prim attributes, which represents the curve prim index to be used for the extrusion and mod(%) can be used to avoid overflow.
extrusion_multiple_ids_spline.hipnc (176.2 KB)
Aizatulin
Wow! Thanks for that Aizatulin. I'll have to break this down to understand it. I'll return once I've gotten a better understanding. My knowledge of those "block begin/end" nodes is li mited.
EUREKA I've finally got what I wanted.
I"M able to create a ribbon out of the curves I'm generating from my pop net. My mistake was thinking that I needed a line to sweep along my curve. Apparently that is NOT the case.I was thinking this sweep node operated like the old one, but all the features I wanted/needed were in the new one.
The goal was/is to see if I can get some interesting Curve meshes for swoops , swooshes, and soulercoasters.
