My attribute noise node is different than in the tutorial [SOLVED]
   4411   2   0
I'm following a tutorial from nine between (this one https://youtu.be/SnGSCO0CwAc) but in his version of houdini (17.0), his attribute noise node has differents parameters than mine, I can't follow the tutorial because of that.
this is my version of the node :
and this is his version (I can't screenshot the entire node, but even the first parameters are different in his version) :
I don't know what to do.
Edited by darkwinds95 - March 3, 2021 03:42:08
change Assets/AssetManager/Configuration/AssetBar to Display Menu of All Definitions
this will enable Asset Bar on top of the parameter pane
select your node and you will see attribnoise::2.0 in that bar, change it to attribnoise which is the old node type
Thanks !
