I'm using Houdini 18.5.532 with Redshift 3.0.39 and I've been trying to check the Redshift render settings on some older Entagma tutorials, believe most were made in Houdini 17-17.5, so not that old, but if I don't have Redshift open I always get this warning with broken material nodes showing up in the mat context:
houdini bad node type found: redshift_vopnet in /mat
skipping unrecognized parameters...
...and, pretty much all RS parameters are skipped...
However, if I close down the project, switch to a Redshift layout and then open the project again, less parameters are skipped and the materials show up in the mat context, but I still get skipped parameter warnings for the materials like the ones in the attached screenshot.
At this point, the materials seem to render correctly, but I wonder if the skipped parameters are something I need to be concerned about? I imagine this is because the Redshift material nodes have changed slightly over the different Houdini and/or Redshift versions and parameter names have changed. Am I correct in thinking this?
That said, do I always need to have a Redshift layout up, when opening a project where RS was used? If I have Redshift installed it would be nice if Houdini just automatically recognized all the RS parameters. Would that be considered a bug? If so, should I report it here or on the RS forums? If not, do you have any tips for opening RS projects without breaking everything?
Houdini 18.5 Redshift Warnings
4246 2 1-
- BenjaminMarkus
- 33 posts
- Enivob
- 2659 posts
Nah, it's the way Houdini works.
I've even seen warnings after saving a new project and opening it back up using the same version. WTF? How come Houdini can't understand the file it just wrote..?
Edited by Enivob - June 12, 2021 08:18:45
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- kumpa
- 44 posts
